On #7 your test light should get brighter and dimmer when you turn the headlight switch knob with the lights on. If it doesn't then you have a bad HL switch.
turned headlight swtich on, connected light to #7 and turned the headlight knob, it doesn't really "dim" but lights on then off.
if it's specifically supposed to dim then it really didn't..
also ran a hot wire from battery and tapped fuse connections, with headlight switch on or off, i got no dash lights.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
