The voltage limiter for the gauges on the back of the dash has nothing to do with the lights. Sounds like the dash light rheostat part of the headlight switch is bad.Use a test light to check for power at the dash light fuse. It is fed by the headlight switch. If it brightens and dims from the HL switch you can rule out that switch.
