It's a procharged hemi making 1200hp/1000tq in a 4000lb roadrunner
I had raybestos blue clutches in the first drum with the waffle style sipes.
The tcs drum has 6 alto red clutches.
We did air checks for clutch engagements.
..... and HOW MUCH line-pressure are you running ?
EXACTLY.......It'll need at least 150 to 165LBS of line pressure.....
If you can't handle the truth, you're living a lie.......
