not enough cam for low 11's unless you have a lot of gear. a 557 would get you close and you don't need the heavy 6-pack rods. You probably don't need to stud the motor either. BB heads seal up pretty good, especailly with only 10-11:1
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
