That is what I was accually going to do. But I thought they were like that for a reason, so I just figured Id coppy.
Do you guys think the 30 ft lbs is good??
Oh and Randy, my header tube is in rout, and I plan on dropping the new bullit inn this next week. SUPER excited!!
Im sure Im gonna have to jet up, but I dont know how much.
Kasey
I torque 3 things on a engine, mains, rods and the heads
the rest gets the normal twist of the wrist to what
size bolt it is.... look up a torque chart for assorted
size bolts... take a couple pieces of material
and get use to different torques using a ratchet
then check them with a torque wrench... you will
be surprised at what you can pull... on the rocker
shaft hold downs I would give them 35
