Quote: I did not see it mentioned but I would first check to see that you have the throttle plates open all the way when you have the gas pedal to the floor. It will kill et from start to finish. Although most of the other comments about degreeing the cam and so on are things that should also be checked. Good luck!
You would be surprised at how much the blades can be closed before it really has ant effect on the ET... I tried slowing my car down to 10.0 and I am at a little less than 1/2 throttle and without short shifting it would only slow it about .6 ... thats from 9.0
