Quote: never seen a comp cam way off run several checked all with degree wheel i always check mine i have seen one that was WAY out there wasnt a comp ,, used to be a guy live here who worked at comp learned alot about cams from him done alot of work with the ss guys back in the day more problems with gears and chains than any cams by the way
I had one that the key way in the cam was cut 29* off so if you lined up the dots it CRASHED big time, without degreeing the cam it CANT BE SAID its straight up or not... of course you can guess all you want
