I am pretty sure you need notched floats with those jet extenders. If not I will hold your float level way to high. Fuel will come spilling out of every orifice. Learned this the hard way!
If fuel is coming out of your vents most likely your float level is too high. Get it down to where it is just trickling out of the sight hole and you should not see that problem anymore.
