...or you could have taken my advice and spent 5 to 10 minutes max and the pump arm would have cleared the lower hole with no problems whatsoever.
I do have the exact same setup as you do; SV1, Jegs bracket and Lokar cable and it works perfect.
mine will not bolt in that front lower hole(toward rad). you say yours does? when the throttle opens up the pump arm lifts and hits the bolt..
did you use higher spacers for the bracket? thx
Mopar Performance
