Throw the cable out and fit your car with a solid rod.
already got $130 into this hi tech setup
Dominick I used the setup on the top hole with my last dominator with no issues ... This thing is kicking my but down to the last parts...
If the pedal worked with the dom... measure the difference
between the length of the 2 arms(to the holes) to
see what ratio you need
