This is the stick and ball that was in my 70 RR E63/D21 383/4-speed when I bought it in 1982. The ball is plain white (now yellowed) no markings, no part numbers, screwed onto the stick. The stick is marked 4078 maybe 4079. Questions:
1. Were all D21 4-speeds pistol grips?
2. Is the build sheet J42 'Pistol Grip Trans Knob' ever marked? Mine is blank (1970Chargerregistry has them all blank as well).
3. Is this a 1969 part? A 3-speed part? Is the ball Mopar? Could this be correct?
The 4078 handle was the aftermarket handle used with their Competition Plus shifter. Also the 70 RR used the Pistol grip which had a slide-in fitting rather than the (2) bolts...
Just my $0.01..
