I'm going to put my vote in for the 220v unit as well. You can always use smaller wire and lower amps for sheet and exhaust but with the 110v unit you can only turn it up so high. And as was said previously, one you start it snowballs. You know you'll want to weld up a new set of awesome ramps!!
