If the vehicle is not working, and you can't make it work, talk to the guy thats been doing it since dirt was new. He will likely help you(at least a little). Then you will likely become friends.
Then, after you've done it while, and your stuff is working, help the next rookie. Again, you will likely make another friend.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
