Quote: Actually I might be more concerned with the valve locks
Are those stamped locks or machined? If they are not machined I'd toss them
Also I would machine and put rockershaft stands on there before I'd use a shim. another
The locks are the ones supplied with the heads from Indy. I would say they are stamped, but I am not 100% positive. Whats the failure mode with stamped locks?
