Guys, it does happen. Two years ago I was having trouble with my trans puking fluid after a couple runs out of both the vent and the dipstick tube. We fought the problem all year, taking the trans completely down twice and several discussions with a couple of trans companies. I finally threw it out on this board and my problem ended up being the filter in the Moroso cooler. I took it out and no more puking. During thid period if I saw even a little bit of fluid I'd put it in the trailer. Wasted a bunch of money that summer.
Several years ago I hit some fluid at the big end of an 1/8th mile track. Only going 102 at the time but I'll tell you I don't want to do that again. Went thru the traps sideways.
I don't mind buying an approved tube if that's the requirement.
we knew there had to be one. theoretically speaking, of course.
for what is the good life if not doing things thoughtfully?
