Re: 625 AFB on 340 too rich, kinda long...
[Re: fshd4it]
#591455
01/23/10 07:37 PM
01/23/10 07:37 PM
Posts: 711 Montana
Posest
Montana
I don't believe the fuel pressure is excessive- I'm running a carter mechanical pump (one of the ones that bolt together), but again not sure of psi. I checked the rod plungers/springs, they're pulled down at an idle. I gapped a new set of plugs .050 & installed them- it actually seems to be a little better, odor/smoke wise. And a bit snappier when I blip the throttle. Only concern is they are rn 14 yc plugs, and I don't want to run too hot. I'm going to go get a new set of 12s right now & try them,too.
Check your pressure. I have had fits like this when the fuel pump was stock. It is hard to tell without a gauge what psi you have. I had a carter pump on mine also that was too much pressure. I have had this problem on my 340 and several smallblock Chevrolet's. Now I just automatically put in a regulator. I hate fighting carb troubles and almost every time is is over pressure on a carter or edelbrock.
Entire Thread
fshd4it
01/23/10 03:49 PM
stumpy
01/23/10 04:01 PM
fshd4it
01/23/10 04:12 PM
Dodgem
01/23/10 04:48 PM
minnesota guy
01/23/10 06:04 PM
fshd4it
01/23/10 06:20 PM
62maxwgn
01/23/10 07:23 PM
solarguy
01/23/10 07:43 PM
aarcuda
01/23/10 07:52 PM
fshd4it
01/23/10 08:08 PM
minnesota guy
01/23/10 08:17 PM
minnesota guy
01/23/10 08:27 PM
RapidRobert
01/23/10 09:04 PM
fshd4it
01/23/10 09:52 PM
RapidRobert
01/23/10 10:34 PM
fshd4it
01/23/10 11:08 PM
Baxter61
01/23/10 11:13 PM
Posest
01/23/10 11:37 PM
70AARcuda
01/24/10 12:41 AM
fshd4it
01/24/10 02:08 AM
Posest
01/24/10 02:29 AM
minnesota guy
01/23/10 07:54 PM
minnesota guy
01/24/10 01:54 AM
