Mr P Body: Is that 4" to C/L mean 4" above C/L?
4" is to the center line of the wheelie bar wheel,
in gear... in the pic in my sig they were set at
6" for show and tell... if you set them to high you
can have to much momentum going up and bottom out
the spring and unload the tire. Also my set up is
using a trans brake... go a little higher if foot braking
(that will roll the pinion up higher)... in that pic
the 60' was 1.20 or 1.21... I set the right bar
1/4" lower than the left
![](/ubbthreads/images/graemlins/wave.gif)
