Yeah, I really like the RAS rocker arms and I like the guys at RAS. Gary and Blaine are both cool guys to work with, laid back but very sharp.
I think I'll run the RAS rocker arms just because the motor should make a little more power with the extra lift. Also, the 1.60 arms give me quite a bit more pushrod clearance. The Comp rocker arms were pushing the pushrods out so close to the head that I was thinking I needed to grind more clearance. The 1.60 arms pull the pushrod in enough that I don't need to grind on the heads so the knocks another issue off my to-do list.
