Andy, what distributor and ignition box are you running ?? We have your wires finally done. Taking pics of them today, and sending them off..How much do you think they would need to be added to fit them on an engine in a car ??
Hi Rick,
I measured up the wires for the Jesel belt drive distributor. The following lengths should work pretty well with dyno headers and Indy heads. The wires will loop down under the heads which works great on the dyno but might not work in a car.
1 wire at 24 inches, 3 at 33.5 inches, 2 at 38 inches and 2 at 41 inches. The Jesel distributor has HEI style terminals. The wires need to have 90 degree boots on both ends. The measurements are from center to center of the boot. (center of the spark plug to center of the HEI terminal)
