Re: Racing with A518 -46RH transmission
[Re: Adobedude]
#56643
04/19/08 05:15 PM
04/19/08 05:15 PM
I do believe if someone took a stock computer controlled 46RE that was shifting at 4500 rpm, or when it felt like it (as they seem to do) and swapped in a built 727 with a manual valve body, the results would be surprising.
If the shift rpm is all that's holding you back I wouldn't be giving all the credit to a 727 if you shifted it higher and went quicker. Why can't you shift your 46RE manually if you need higher shift points?
As for the 1 1/2 second claims by SMR....I've dealt with SMR in the past. In my (lengthy and very expensive) experience, there is certainly no lack of BS from that operation!
