I use Moog rubber bushings for the LCA and strut rods. Not all rubber bushings are equal, Moog is still the best IMO. I use poly for the UCA and the anti-roll bars. I also only use Moog parts for ball joints, pitman & idler arms and tie rod ends. IMO suspension and brakes are not the place to use the cheapest parts. After all they only hold the wheels on and stop the car.
If someone made an offset UCA bushing in poly I'd say go with that, but since I haven't found one, your only choice is the K7103 from Moog. And yeah, lots of other front end suppliers used junk ball joints and the like. Stick with Moog. Use poly for the sway bar end links and frame bushings, and in the leaf spring front and rear bushings, rubber for the front end bushings.
