I use Moog rubber bushings for the LCA and strut rods. Not all rubber bushings are equal, Moog is still the best IMO. I use poly for the UCA and the anti-roll bars. I also only use Moog parts for ball joints, pitman & idler arms and tie rod ends. IMO suspension and brakes are not the place to use the cheapest parts. After all they only hold the wheels on and stop the car.
