... go with rubber lower bushings,they are an interference fit and the rubber will deflect and provide some additional suspension.
don't tighten your lower a-arms until you are at your ride height or they will be permanly twisted and you'll wonder why they didn't last.
...those plastics styles need lube to install and just take up space...moving with the torsion bar..i think...al
