Could I splice the wires and fix them together with a single end and fix the problem or would that just mess things up more?
connect the blue and the brown wires together on the one connector & you're set. (4 pin ECU I'm assuming) EDIT you have the OE double connectors/wiring harness that were on each end of the 4 terminal ballast and you plugged your new 2 terminal ballast into one half of each of these plastic connectors? If this is correct jump the blue to the brown.
