while a helper turns the key to "start" you check voltages at the "point" of the pentastar ECU connector and at the coil positive primary terminal with your VOM & if no fire work your way back to the bulkhead via the ballast & further upstream (under the dash) if need be & can take off the brown "sol" wire at the starter relay to keep the starter from running down the batt if needed.
