Quote:the ratio is 5.4:1 and is rated to spin 65,000 rpm (impeller speed) F-2 procharger so you can OD that to 58% if you shift at 7,000i think.i will check the math again.http://www.google.com/url?q=http://www.p...wvH2ky4NXKqM0Rw38lbs and 2700cfm
