Just curious, have you had the bathtub/intake gasket off on all those 'matching numbers' cars?
I've never owned one with the original intake gaskets, they'd all been R&R'd at one time or another, but I do have good clear photos of the block pad stampings as well as the block VIN# sequence stampings and matching VIN tags if you ever need to see proof to say, settle a bet?
I wasn't asking if they had original valley pan gasket, rather I was asking if you had viewed the complete pad. I've noticed that as a general rule, the 'C' is at the back of the pad and the valley pan is usually covering it.
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
