Quote: The "C" on the pad means "Special Rods & Pistons". That is a six pack block. There should also be a "C" on another spot on that block if it's a real six pack and someone hasn't just put the C on the pad. I'll PM you with that location.
so it's a secret??? I thought this was a "question & answer" board...just think the havoc I could wreck if I knew the secret location of the magical "C" stamp.
