Checked that. Nothing obviously hitting each other.
I did notice a tiny bit of movement in the u-joint on that side. Everything was still on the ground though, so I couldn't turn the wheel.
Most likely the u-joint then?
If you ever find yourself in a fair fight, your tactics suck.
