Thanks guys!!
I've already got a pair the front body mounts fabbed up and tacked on, not 100% if they are where they are going to stay, height wise. Looking much better though!
Last night I took the leaf springs and rearend out, I need to move the leaf springs under the frame, they interfere with the body subframe and I don't want to cut into that.
After I get the leafs springs shuffled around, I can build the rear body mounts and set the rear of the body down over the frame, which should drop the car pretty heavily.
After I get all that stuff done I figure I'll take a few more update pictures, because it will really start to look like a car!
nice job,,what was the wheel base of the dakota frame to start with ?
There are three different wheel bases, mine was the shortcab longbed which was 123.9 inches.
