You'd have to check the factory service manual for a spec but most shift around 45-4800 @ WOT.. Increasing the length of the "kickdown" linkage (throttle valve pressure linkage) can have some minimal effect but the max TV pressure is equivalent to line pressure so governor valve weight is the true limiting factor.. TV Pressure can effect 1-2 & 2-3 part throttle shift points..
