My cam is [Email]272@050[/Email] 610 lift. I have a TA 4200 convertor. It flashes 5400. If yours is a good converter. It might be very close as is. Are you going to use the cast or forge crank? Jim
I'm thinking cast steel for the crank to keep the price down as long as it will hold up ok. I'd like to stick with a solid cam, either the one i have or a bigger one if it will work. Here's the specs on the .528 solid i have. Not sure what the converter flashes at not but when footbraking the tires break loose about 3800 rpm. Thanks.
Cam Style Mechanical flat tappet
Basic Operating RPM Range 2,800-7,000
Intake Duration at 050 inch Lift 241
Exhaust Duration at 050 inch Lift 241
Duration at 050 inch Lift 241 int./241 exh.
Advertised Intake Duration 284
Advertised Exhaust Duration 284
Advertised Duration 284 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.528 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.528 in.
Valve Lift with Factory Rocker Arm Ratio 0.528 int./0.528 exh. lift
Lobe Separation (degrees) 112
Intake Valve Lash 0.028 in.
Exhaust Valve Lash 0.032 in.
