Thanks for the info Robert, i forgot you were building one. I need Piston ideas too, something in the 10-10 1/2 comp range.
with 72cc J heads, KB forged flat tops will be 10.5:1 with a fel pro 8553PT gasket (.054" thick) will net you 10.5:1
the SCAT I beams probably won't need block clearancing. stockers will.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
