Quote:Quote:Thanks for the info Robert, i forgot you were building one. I need Piston ideas too, something in the 10-10 1/2 comp range. with 72cc J heads, KB forged flat tops will be 10.5:1 with a fel pro 8553PT gasket (.054" thick) will net you 10.5:1the SCAT I beams probably won't need block clearancing. stockers will.
