alittle while back i had the same problem on a ford.
an old time boat mech told me to heat the head up around the plug as hot as i could get it with a propane/map torch and use a plain old house candle and melt the wax around the threaded part of the plug.
once it was hot enough you could see the wax traveling around the threads and after a bit the plug came right out.
