Quote: So the plate in the distributor will actually have a number on it as stated above? Can I use two factory stiff springs, or are those too strong?
(1) yes (in dist degrees) (2) yes too strong, the stiff factory spring w the long loop, toss it & keep the light oe spring and add another one (not sure what is available)
