My 360 block has the stock spec. So if I use my old 340 heads (casting no 3418915, 2,02 inlet valve) and a .039" gasket, no milling should be necessary anywhere, right ? And the quench will be around the ideal ,040 , ( will of course have to check)
Is the.039 head gasket stardard in kits or do I have to specify.
So the 340 heads + KB 190 + XE284H is the way to go, I understand. Forgetting the alu heads also saves a lot of money.
