A friend of mine bought a new aluminum shortblock from Indy last year and ran it with no problems. Over the winter when he had it taken apart, the shop found 3 or 4 of the cam bearings loose and had to have the block cam bearing tunnel cut for the 429/460 Ford size cam bearings. Comp makes a cam for Mopars that fit that size cam bearing. Good luck. Dyno
