My hemi is fuel injected. If you don't like quick starting and smooth idling than stick with a carb. Tim at FHO has a 2-4 fi setup that once the air cleaner is on you would never know it was injected. The biggest thing is the system that you run. I have a Fast xfi but if you get into buying a older antiquated system the tuning headaches wont be worth it. Fuel injection is awesome.
