is this the one your useing? Thyis is the one i was looking at. LUN-60303LK Cam Style Hydraulic flat tappet Basic Operating RPM Range 1,800-6,200 Intake Duration at 050 inch Lift 226 Exhaust Duration at 050 inch Lift 234 Duration at 050 inch Lift 226 int./234 exh. Advertised Intake Duration 268 Advertised Exhaust Duration 276 Advertised Duration 268 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.494 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.513 in. Valve Lift with Factory Rocker Arm Ratio 0.494 int./0.513 exh. lift Lobe Separation (degrees) 110 Camshaft Gear Attachment 3-bolt
that's the one I'd go with, just make sure your springs can handle the lift. another good choice would be an Engle 2356-H. it's 272 adv, 224@.050, .504" lift, same lobe intake and exhaust.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
