ok. instead of tapping the ground then, I'll hold it grounded, and lift to see if it fires the coil then.
if it's supposed to be grounded EXCEPT when the coil fires...then why did my negative terminal have voltage on it? if it's grounded, shouldn't it read zero volts, and then read volts when the ground is removed, and thus firing the coil?
