Re: It won't start. My turn!
[Re: 64Post]
#358336
06/26/09 08:25 PM
06/26/09 08:25 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'm at work right now, and haven't had a chance to do much else....
regardless of if the coil and box get power in "start" vs "run" they are definitly getting power in "run" and since I'm not using a ballast, I see no reason why they wouldn't get power in "start" as well.
However...in "run" when I grounded out the coil negative terminal, shouldn't the coil have sparked out the main wire? It wasn't I was getting sparks from my jumper wire, but nothing out of the coil...
You had to jinx me... now my junk won't start.
sorry about that!
I really want to replace the coil...I don't know why. but I also can't afford to swap parts if it's not the coil!
Its just REALLY weird how this happened at the same time that I re-wired the trunk mounted battery and the alternator to put in a master kill switch.
of course, the coil is right next to the alternator, and I might have knocked it working on a stuck bolt...which is why I'm suspect of the coil.
**Photobucket sucks**
