I guess I'd have to eat my words!
http://www.carcraft.com/techarticles/ccrp_1110_pump_gas_small_block_mopar/
Hey Brian, what does a motor like that cost???
I think CC did the cost at the end of the article...something like 10K or 11K.
Had alot of guys question the 9000 series crank...I tell them if the BLOCK doesn't break first, I'd be surprised!
Those 9000 cranks are pretty tough...if you don't detonate the engine.
If your going to race it alot, the 4340 crank is a better choice as it will go many many years without breakage.
But I would still use the I beam rods at that power level.
Brian
Brian Hafliger
