Another easy test:
Make sure the float level is correct, find a stretch of deserted road, hold it wide open until it falls on it's face then turn the ignition off immediately, without letting up on the throttle. Coast to a stop and check the float level again. If the bowls are dry, you just eliminated a bunch of stuff on your checklist.
I can try that tomorrow, I will be on some back country roads. If the bowls are empthy after this test I just prove there is a fuel problem but it doesn't help me identify where the problem is right.
