Well, thanks for the replys
I really need to do some troubleshooting here before I throw money at more parts.
I have a checklist...
Pull the outlet side of the pump hose off and use the started to see if its putting out the fuel it should.<<<<<<<>>>>>>>>
Volume check off starter only is not enough,the car should run for 20 seconds on what is in the fuel bowls.Check with car running
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
