I noticed when I was looking at the units currently available that the listing didn't show this picture. The unit didn't come with instructions other than to say the unit needs to be tilted back slightly to allow the condensation to drain.
The picture somewhat shows the wiring, pretty straight forward, a ground, a red wire with in line fuse that goes to 12V switched and a green wire that needs to run to the compressor clutch. The switches are pre-wired.
Hope this helps.
[Linked Image]Z AC W by M Patterson, on Flickr
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
