A quick update on the AC. I got the ducting run and although the heater hoses and AC lines have yet to be built/connected, I was able to test the unit and check for the volume of air that would come out of the vents. I’m very happy with the results. There’s good velocity coming out of the under-dash vents and the floor air diverters work well. I’m especially happy with the defrosters, they shouldn’t have any problems keeping the windshield clear (this was the major complaint I had with the last aftermarket unit I installed).
Most of the time spent on the car the last couple of weeks has been in the interior. I’ve been sorting out wiring for the accessories I’m adding (electric PS, AC, Radio, GPS, cruise control etc). We also redid the carpet in the rear seat area. I’ll post more on that when I have that part wrapped up.
Yesterday we were at a point where it was time to install the mock-up motor and transmission in the Green car. We’re doing a final mockup basically as a quick check to make sure that no new clearance issues popped up due to any differences in the bodies. I figured that there would be some additional clearancing required but to my surprise the engine and transmission actually seems to fit better in this body than it did in the other 68.
Z MU F by
M Patterson, on Flickr
While the mockup engine and transmission is mounted I’ll go ahead and finalize the steering and probably some other little things prior to installing the real engine and transmission.
