Sooo close. You'll totally have a 9.9x timeslip before the end of the year with that mph!!
I'm going to try again this Friday night. We have a test and tune at KID and I have another full bottle already in the car.
*Edit*
Didn't get to go. Dad is 86 years-old and had a nasty fall last week and ended up in the ER. He lives 3 hours away so we took Saturday to go and see him. He is doing well all things considered.
It uses about 2.5 lbs. per pass, so a bottle is only good for about 2 full passes.
what is the fuel psi flowing ? and do you adjust it when the da is so bad?? do you have access to water grain info?
that 10.07 is getting there for sure now
5psi
No.
I look at the Air Density Online website for DA, Water grains, etc.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
