Originally Posted by IMGTX
Originally Posted by moparmarks
The front bracket for the auto setup has the bell crank bracket mounted to it thus the two welded nuts in it.
Yes in that picture with the three brackets it is the upper left.
If you are not going with the slapstick factory shifter and are going to put an aftermarket shifter you can modify the manual shifter front bracket to work.
If you are going to use the factory shifter you need that automatic set. That large boxy bracket in the top picture holds both the shifter and the console.
He says in his original post that he has the shifter mount bracket already, I ASSuME that it's the correct one , like the one in the picture?
running up my post count some more .
