Originally Posted by ValiantRich
When I used steel lip seals my transbrake would sometimes not hold on the starting line. Changing to Teflon seals cured this problem but over time can wear a groove in the aluminum drum. Custom making a steel sleeve pressed onto the aluminum drum cured the problem. Thanks to Pro Trans.
Those are usually referred to as seal rings , not lip seals ?
running up my post count some more .
